![]() Drives: 08 2dr Join Date: Feb 2014
im getting p2757
OK. That is definitely the code for the Shift solenoid valve SLU. There are actually 5, not 3, but the SLU is easily replaceable.
You can test the SLU to determine if it is bad or if the torque converter is bad. You can grab the AT service manual from the Micro Image forum: http://www.microimageonline.com/foru...32-YARIS-FILES
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
