Old 02-13-2014, 09:57 AM   #1
esse10
Drives: 2009 yaris 2 door
shift fork
I have the same problem.,
So how do you get to lubing the shift fork ? and what parts do you need to remove to get to it. is it the area with the blue arrow in this picture? is there where we need to lube?
File Type: png toyota-yaris-clutch-parts-components.png (36.9 KB, 255 views)
esse10 is offline   Reply With Quote
Old 02-13-2014, 11:10 AM   #2
The black arrows in your diagram point to where Toyota says to apply "Toyota Genuine Release Hub Grease or equivalent". You can access the fork by pulling the fork boot and using a long swab to apply the grease. You might want to start with applying grease to the external point where the fork and the slave cylinder meet.
Old 02-13-2014, 02:48 PM   #3
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
You Really need to get deep inside with lube lol ah and try putting lube in all shift linkages removing the boot. etc.HERE'S THE OTHER COMPONENT TO LUBE.
http://www.yarisworld.com/forums/sho...ghlight=squeak
Old 02-13-2014, 03:14 PM   #4
esse10
thanks
Thanks fellas , I just realized that I should have done it when I replaced the radiator a few months back...UURRRGGG!
BTW great pictures ctscott
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Way to shorten distance on clutch pedal? kac Performance Modifications 2 07-23-2009 06:42 PM
squeaky clutch TickleTimeTim DIY / Maintenance / Service 4 04-28-2009 11:36 AM
Car/engine shake when releasing the clutch pedal hystria DIY / Maintenance / Service 16 07-22-2007 07:56 PM
Hard clutch pedal ? hystria General Yaris / Vitz Discussion 5 05-11-2007 06:12 AM
