![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
Gotta say, i had like a mini heart attack reading this thread. I always worry about breaking that thing off.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#2 | |
I thought I'd clear up what I did to remove it in case this happens to anyone else. When It broke off, I barely exerted any force on it, so I'm not sure how it snapped. I attached a photo to show how much of it was stuck in the head, basically the entire half that has holes in it. What I ended up doing was grabbing this little guy from the hardware store, which is basically just a coupling nut with a hook on one side and a loop on the other. I bent the hook so it was more of a 90 degree angle and fished around inside the part to find one of the holes in the side wall. When I found a hole, I put pliers in the loop end of the little tool and gave it a good pull and wiggle and it finally popped out. I then immediately poured myself a whiskey coke. Hope this doesn't happen to anyone else. If it does happen, the little hook method literally took me about a minute to extract it rather than struggling with pliers for another couple hours. Cheers!
| DIY - Carbon fiber wrapping | Brian | Wash, Wax, Detailing, Exterior Repairs | 15 | 07-10-2016 12:34 PM |
| Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) | chalked | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 01-26-2013 02:29 PM |
| Part fall off | razingman | DIY / Maintenance / Service | 2 | 12-29-2012 07:08 PM |
| 2008 OEM S model Liftback Lip kit Part numbers | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 17 | 07-26-2010 01:33 PM |
| NEED HELP - Yaris suspension part | Trish | General Yaris / Vitz Discussion | 10 | 11-07-2009 01:44 PM |
