Old 02-16-2014, 12:30 PM   #1
The only ignition switched power sources under the hood are ones that are critical circuits (ECM power feed and fuel injector power feed), so you would want to run a wire through the firewall to feed them. The pink wire on the ignition switch connector is a good source of ignition switched power, but I would use that to feed a relay coil where the relay contacts then switch the power to the lights. If the LEDs are low power devices, then you would be OK feeding them from the pink wire, but I would still put a fuse inline with the feed to the lights.
Ts/rs rear LED lights deadcrow Items for Sale by private party 13 01-23-2012 12:43 PM
LED Strip Lights ecmiyake DIY / Maintenance / Service 0 07-22-2010 10:32 PM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
Test Fit $50 Or LED Tail lights winson California 6 01-05-2010 08:31 PM
