Old 02-16-2014, 09:22 PM   #1
yaristar
Drives: 2008 yaris sedan
yes that was the elm 327 i only use that to read codes and i disconnect it every time
what can it be if all those voltages are correct?
I really have no idea were to go from here
yaristar is offline   Reply With Quote
Old 02-16-2014, 09:40 PM   #2
Check the voltage on the two CAN bus wires on the smaller connector (Green wire in pin 20 and white wire in pin 21) with the ignition on.
Do you just use your ELM with a smart phone, or have you used it at all with a PC?
Tags
cluster, door indicator, gear indicator, parking brake warning, tachometer
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
