Old 02-17-2014, 02:37 PM   #1
yaristar
Drives: 2008 yaris sedan
i checked pin 20 (green) and pin 21 (white) on the small 24 pin wire that plugs into the cluster, is this the connector you were referring to?
yaristar is offline   Reply With Quote
Old 02-17-2014, 03:10 PM   #2
Yes. On the right side connector. Those two pins, with the connector plugged in and with the ignition on, should each read about 2.5 Volts to ground.
cluster, door indicator, gear indicator, parking brake warning, tachometer
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
