Old 02-17-2014, 05:48 PM   #1
yaristar
Drives: 2008 yaris sedan
yes i think my proscan version 5.9 allows me to use terminal mode
yaristar is offline   Reply With Quote
Old 02-17-2014, 06:00 PM   #2
OK. Go into terminal mode and do the following. The lines above the > lines are what you need to type into the top bar and hit send and the lines below are what you should see as responses.
ath1
>OK
atsh 7C0
>OK
21 61
>7C8 03 61 61 00
21 24
>7C8 03 61 24 FF
21 E1
>7C8 03 61 E1 00
13 81
>7C8 02 53 00
Tags
cluster, door indicator, gear indicator, parking brake warning, tachometer
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
