Old 02-18-2014, 06:44 AM   #1
Air adjustable helper springs may be your best bet for the rear. They are under $100 and work well (I use a set on Crashy to keep the rear from sagging when I have her dump bed full of dirt).
This is the kit that I used:
http://www.etrailer.com/Vehicle-Susp...id=20081014545
Old 02-18-2014, 12:55 PM   #2
hairdresserscar
Drives: 07' Yaris sedan
Is that all you used to lift the rear? Couldnt find how you did it on the crashy thread.
hairdresserscar is offline   Reply With Quote
Old 02-18-2014, 01:13 PM   #3
Yes. On Crashy the rear was always higher than the front, as with everything including the hatch removed there was zero weight back there. When I cut the top and added the power dump bed I found that once I put some weight in the bed that the rear would sag to the point where the tires would rub, so I added the helpers. Now, I can carry 1000 lbs of topsoil and she doesn't squat at all.
fnkngrv's custom trailer build log fnkngrv Off-topic / Other Cars / Everything else Discussions 5 10-12-2012 01:24 PM
Dirt Road Yaris carlghoul Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-16-2011 06:22 PM
Yaris Off Road??? Rutherfordman General Yaris / Vitz Discussion 18 02-26-2010 10:13 PM
