Old 02-18-2014, 11:42 PM   #1
yaristar
Drives: 2008 yaris sedan
I did not match the numbers but the same problem persists after replacing the fuse box the fuse box i got was off of a 2007 yaris sedan loaded and mine is a 2008 toyota yaris base
Can it also be possible that the engine control unit can also be bad?
yaristar is offline   Reply With Quote
Old 02-19-2014, 06:29 AM   #2
I don't believe that it is the ECM (engine computer), as you would have a check engine light if he could not communicate. Were you able to check that top rear connector (it just has 4 wires in it, but they are the CAN bus wires for the cluster and for the body ECU).
While you are back there, see if you can get the part number off the new one. It is on a paper label on the back.
cluster, door indicator, gear indicator, parking brake warning, tachometer
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
