![]() Drives: Toyota Echo Join Date: Feb 2014
Thanks every one for your input and help, I've already ordered specific oil lines from Japan. I will tap into the oil feed from the oil sensor on the front of the engine under the intake manifold, then ill tap into the upper oil pan assembly for the drain tube.
As for the water feed, i've ordered some specific fittings that i'll get my engineer to weld onto the in/out coolant tubes for the engine. More photos to follow. |
| Zage turbo kit oil feed line fitting size?! | DKN-YARIS | Forced Induction Forum | 1 | 02-17-2014 11:18 PM |
| Need Feed Back | Asif | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 12-18-2012 05:07 AM |
| turbo feed lines | 1.5ty | Forced Induction Forum | 10 | 09-06-2010 10:41 PM |
| Afe intake feed back required. | 1NZYaris1 | Performance Modifications | 51 | 03-20-2009 07:25 PM |
