Old 02-23-2014, 09:46 AM   #1
shockedmustang
Drives: 2008 yaris 3 door hatch
Thats where im confused the alternator will charge fine for a bit then just stop charging for no reason and this is the third alternator that im on. The ground I had in question is the one that runs from the motor to the body of the car im wondering if that is bad. But I did run another cable from the alternator's bracket to the batteries ground cause of the question but it still happened.
shockedmustang is offline   Reply With Quote
Old 02-23-2014, 10:15 AM   #2
That is very odd that three have behaved the same. The charging system on the Yaris is very simple, so it isn't like there is a feedback loop that is opening.
Another thing to check is where the positive lead from the alternator hits the positive battery terminal. It comes into one of the large connectors on the bottom of it. I have heard of a couple of people having that connector severely corroded.
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
CV joints or axel issues aucorium DIY / Maintenance / Service 1 02-17-2010 09:10 PM
For the TEIN S tech users any sagging issues? marcus Performance Modifications 7 01-28-2010 04:06 PM
Exhaust clearance issues... YaYa1320 Performance Modifications 12 10-07-2009 04:46 PM
