Old 02-24-2014, 07:19 AM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Patience is everything it took me to peel it off ;)
dj92 is offline   Reply With Quote
Old 02-25-2014, 08:13 AM   #2
jazzyb88
Drives: 2009 Hatchback
And it was fine on both sides?
If so...I'll give it a go but suppose it tears, I assume you can replace the whole sheet quite easily? Must be something you can buy from your local DIY shed?
jazzyb88 is offline   Reply With Quote
Old 02-25-2014, 08:47 AM   #3
I tend to always put at least a small rip in when pulling the plastic, but I just tape the rips with duct tape. Heating the black goo would probably help.
Old 02-27-2014, 03:48 AM   #4
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Just a minor point about the window cranks - many cars besides the Yaris use this kind of clip to hold the window crank on - (e.g. Chevys). Tools for removing the clip are quite common and readily available from parts supply stores.
Sir A.Y. Atoyot is offline   Reply With Quote
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
American colors for the LIftback? debbiezan General Yaris / Vitz Discussion 4 02-25-2006 01:38 AM
