The European ones have a bulb for the digital cluster and an LED for the analog cluster. The easiest way to disable the light either way is to snip the red wire with the yellow stripe on the instrument cluster connector.
The ECM has to ground that wire to make the light come on, so unless that ECM output has failed with a short to ground, the ECM is lighting it for a reason.
| Replacing headlight bulbs | nsmitchell | DIY / Maintenance / Service | 47 | 02-14-2016 09:07 PM |
| Headlight bulb change....more to it than meets the eye... | Yarflana | DIY / Maintenance / Service | 0 | 03-24-2013 08:56 PM |
| Dashboard mount for iPhone 4S? | shima | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-25-2011 09:22 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| "L" shaped HID bulb | big lo | Cosmetic Modifications (Exterior/Interior) | 6 | 01-29-2011 05:26 PM |
