Old 03-02-2014, 09:15 PM   #1
tylerwatts53
Drives: 07 Yaris Sedan
Well, this is getting stranger and stranger. I had disconnected the battery (before I jumped 4A-8 and 4B-11) to reset everything. Now, after reconnecting the bat, the fuel gauge seems to be reading accurately (4 bars) and the car WILL start, but it will only run for 3-5 seconds... sign of progress?
tylerwatts53 is offline   Reply With Quote
Old 03-02-2014, 10:32 PM   #2
Disconnecting the battery made the instrument cluster reset and take an initial absolute reading of the fuel level. When you do a partial fill and don't drive the car, it takes quite a while for the instrument cluster to believe that the level changed.
With those two jumped, I would expect it to keep running. Did you jump it in a solid way, where the connection won't be intermittent?
Also, measure the voltage on 4E-5 (violet wire) With the ignition switch in the ON position and then again after it stops running (without turning the key off).
Old 03-02-2014, 11:23 PM   #3
tylerwatts53
It's alive!
Well, I had not actually tried to start the car with that jumper wire in. But I realized why it was not running for more than a few seconds--I had never put the intake hose (coming from the air filter) back together from when I had sprayed the starting fluid. Once I did that, I put the jumper wire in, and presto, it started up and kept running. I pulled the jumper wire, and it kept on running as if nothing had ever happened! Drove down the road and back about a mile, through all gears, just to be sure--running like the Toyota I know and love!
So should we chalk this up to a case of a bad connection that happened to get tightened up as I went through everything, or should I expect further troubles down the road? As for me, I'll just go about my normal commute and mark it as a miracle (I actually had prayed that I would get this fixed without spending any money on it! The Lord works in mysterious ways... ;-)
Thanks for all of your help--especially Scott.
Old 03-03-2014, 10:01 AM   #4
That is pretty wild. There may be an intermittent connection that temporarily resolved by manipulating the wires.
I completely took apart one last night and was amazed that rather than a circuit board, there is a mass of wire inside that makes the connections between the various functions. There is a small circuit board on the back side, which is the actual body ECU, but other than that it is all punched down wire connections. The relay that you were bypassing is one of the four on the lower right side of the rightmost section.
I suspect that your problem will eventually come back, but at least now you know which wires to jump to get it back going, so you don't get stranded.
Tags
electrical, fuel gauge, fuel pump, won't start
07 yaris lb sometimes does not start :( biggyjiggy DIY / Maintenance / Service 10 07-09-2012 05:59 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
