Old 03-06-2014, 10:22 AM   #1
hockysa
Drives: Yaris
I have read that people have had the AP800 installed on D4D Yaris. I read that it cost about $800 USD.
http://www.conrad-anderson.co.uk/cru...isecontrol.htm
Hi is there any information anywhere on these installs?
I've acquired a second hand AP800 and want to install it on my Yaris and have figured out the wiring except for the accelerator pedal.
hockysa is offline   Reply With Quote
Old 03-06-2014, 10:33 AM   #2
Like I asked on your other thread - What year is your Yaris, as that makes a difference in the wiring?
Old 03-06-2014, 10:43 AM   #3
hockysa
Drives: Yaris
oh sorry didn't see a reply
it's a 2007 Yaris
Old 03-06-2014, 11:02 AM   #4
it's a 2007 Yaris
OK. The accelerator pedal has a 6 pin connector.
1 - White: VCP2 (Sensor 2 power)
2 - Brown: EPA2 (Sensor 2 ground)
3 - Light blue: VPA2 (Sensor 2 output)
4 - Black: VCPA (Sensor 1 power)
5 - Green: EPA (Sensor 1 ground)
6 - Red: VPA (Sensor 1 output)
I haven't seen the install manual for the AP800 for the Yaris, but looking at the pinout of the AP800 it has a high and low throttle position sensor connections.
On the Yaris the VPA signal would be the low one (2.6 to 4.5 V at full throttle) and VPA2 would be the high one (3.4 to 5.0 V at full throttle).
Old 03-06-2014, 11:23 AM   #5
hockysa
Drives: Yaris
Awesome that's perfect
thanks!
you don't also happen to have the same thing for a 2006 Corolla do you?
It's also a 6pin plug but different configuration
*edit*
also where did you find it?
because I've been searching for hours and got nothing
*edit edit*
just googled corolla VCP2 and found it :S
Old 03-06-2014, 12:07 PM   #6
thanks!
*edit*
*edit edit*
I don't have the info for the Corolla, but the pinout order is likely the same with just the wire colors being different. You can verify that by measuring the voltage on the pins where the "power" pins should have 5 volts on them and the grounds zero.
I found a manual for the aftermarket cruise online, but it was not for a Yaris.
Old 03-06-2014, 08:38 PM   #7
hockysa
Drives: Yaris
Yeah I thought the same too but the order is different
yeah? could you link it to me anyway please?
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
