Old 03-06-2014, 11:23 AM   #1
hockysa
Drives: Yaris
Awesome that's perfect
thanks!
you don't also happen to have the same thing for a 2006 Corolla do you?
It's also a 6pin plug but different configuration
*edit*
also where did you find it?
because I've been searching for hours and got nothing
*edit edit*
just googled corolla VCP2 and found it :S
OK. The accelerator pedal has a 6 pin connector.
1 - White: VCP2 (Sensor 2 power)
2 - Brown: EPA2 (Sensor 2 ground)
3 - Light blue: VPA2 (Sensor 2 output)
4 - Black: VCPA (Sensor 1 power)
5 - Green: EPA (Sensor 1 ground)
6 - Red: VPA (Sensor 1 output)
I haven't seen the install manual for the AP800 for the Yaris, but looking at the pinout of the AP800 it has a high and low throttle position sensor connections.
On the Yaris the VPA signal would be the low one (2.6 to 4.5 V at full throttle) and VPA2 would be the high one (3.4 to 5.0 V at full throttle).
hockysa is offline   Reply With Quote
Old 03-06-2014, 12:07 PM   #2
thanks!
*edit*
*edit edit*
I don't have the info for the Corolla, but the pinout order is likely the same with just the wire colors being different. You can verify that by measuring the voltage on the pins where the "power" pins should have 5 volts on them and the grounds zero.
I found a manual for the aftermarket cruise online, but it was not for a Yaris.
Old 03-06-2014, 08:38 PM   #3
hockysa
Drives: Yaris
Yeah I thought the same too but the order is different
yeah? could you link it to me anyway please?
Old 03-06-2014, 08:50 PM   #4
http://nicolas.bct.free.fr/Regulateu...rateur_HDi.pdf
I ran into the diagram for the 05 Corolla and it shows:
1. Yellow - EPA2
2. White - VPA2
3. Yellow - EPA
4. Black - VCP2
5. Green - VPA
6. Black - VCPA
Old 03-07-2014, 03:45 AM   #5
hockysa
Drives: Yaris
Awesome got it installed and working. Just need to calibrate it now
Thanks for all your help
Old 03-07-2014, 09:22 AM   #6
hockysa
Drives: Yaris
omfg so lame... followed instructions to calibrate and now it doesn't work fml
linked the manual I was using
http://www.lupo3lklub.dk/pdf/AP900C_...ion_Manual.pdf
my unit is actually an AP800 but the seemed to have replaced that with a 2 in 1 type unit the AP900c
Old 03-07-2014, 11:00 AM   #7
Will it respond to the "Diagnostics mode" listed in the manual?
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
