Old 03-06-2014, 12:07 PM   #1
Originally Posted by hockysa View Post
Awesome that's perfect
thanks!
you don't also happen to have the same thing for a 2006 Corolla do you?
It's also a 6pin plug but different configuration
*edit*
also where did you find it?
because I've been searching for hours and got nothing
*edit edit*
just googled corolla VCP2 and found it :S
I don't have the info for the Corolla, but the pinout order is likely the same with just the wire colors being different. You can verify that by measuring the voltage on the pins where the "power" pins should have 5 volts on them and the grounds zero.
I found a manual for the aftermarket cruise online, but it was not for a Yaris.
Old 03-06-2014, 08:38 PM   #2
hockysa
Drives: Yaris
Yeah I thought the same too but the order is different
yeah? could you link it to me anyway please?
hockysa is offline   Reply With Quote
Old 03-06-2014, 08:50 PM   #3
http://nicolas.bct.free.fr/Regulateu...rateur_HDi.pdf
I ran into the diagram for the 05 Corolla and it shows:
1. Yellow - EPA2
2. White - VPA2
3. Yellow - EPA
4. Black - VCP2
5. Green - VPA
6. Black - VCPA
Old 03-07-2014, 03:45 AM   #4
hockysa
Drives: Yaris
Awesome got it installed and working. Just need to calibrate it now
Thanks for all your help
Old 03-07-2014, 09:22 AM   #5
hockysa
Drives: Yaris
omfg so lame... followed instructions to calibrate and now it doesn't work fml
linked the manual I was using
http://www.lupo3lklub.dk/pdf/AP900C_...ion_Manual.pdf
my unit is actually an AP800 but the seemed to have replaced that with a 2 in 1 type unit the AP900c
Old 03-07-2014, 11:00 AM   #6
Will it respond to the "Diagnostics mode" listed in the manual?
Old 03-08-2014, 10:37 PM   #7
hockysa
Drives: Yaris
ok found an AP800 manual from a supplier the setup modes are slightly different got it working again but still want to smooth out the cruise control
It seems fine but at 80 km/h it's kind of "jerky" and takes awhile to settle, like its trying to maintain speed by tapping the accelerator instead of gradual pedal control.
There's instructions to manually adjust the INIT, GAIN and PPM but I don't exactly understand what that is yet. Doing some reading on it now
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
