You'll probably notice a lot more driveline vibration, but less free play from on throttle to off throttle.
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
it is definitely different. improved rev response, better grip from the clutch. weird to let out on, it has free travel until the top 75% of the peddle movement, then it starts to grab and is completely engaged by 80% travel. it lets out like a Honda, kind of weird. It will take some getting used to.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
You can adjust all aspects of the clutch travel by adjusting the pushrod from the pedal to the master cylinder. Just loosen the rod back a bit then adjust the top out stopper to take up the slack.
the slack eased its self out. but on another note, the engine mount is either dead or dieing. squeaks with engine movement, running or not, and of course it is the oil filled/ hydrolic one that cost about 1k to get.
If it comes to replacing it just get a used one.
They would appear to be. The ones for the Echo are all totally different.
| Official: Toyota dropping the Matrix after 2013 (from U.S.) | Kal-El | Off-topic / Other Cars / Everything else Discussions | 10 | 08-09-2013 08:49 AM |
| Dropping out of boost/not activating | 47_MasoN_47 | Forced Induction Forum | 13 | 05-06-2013 05:26 PM |
| MPG Dropping | NRclem | Fuel Economy Forum | 20 | 01-07-2013 12:39 PM |
| mpg dropping.. | marcus | Fuel Economy Forum | 14 | 11-10-2010 08:28 AM |
