#19 |
awesome build thread. love your car.
#20 |
![]() ![]() Drives: 2000 Yaris 1NZ-FE Supercharged Join Date: Apr 2012
Sneak Peak
![]() More to come soon. Last edited by iwanttobeamole; 02-19-2020 at 05:47 AM. |
#21 |
underdrive s/c pulley? Sweet!
#22 |
So.....
it turns out that supercharger RPM is not directly proportional to boost. I wanted 50% more boost, so I made the supercharger spin 50% fast. What this got me however was about 200% more boost, about 15psi at 2,000 RPM. Too much! So.. back to the drawing board, I had another pulley made that increased pulley RPM by approx 22%, and this seems to have done the trick. It's installed and going well so far, but the ecu is set to boost cut at about 12psi, which it now hits at about 3500RPM. Had to tweak the belts up pretty tight but they don't seem to be slipping so that's good. Tune is booked for next Thursday. |
#23 |
15lbs is what i want out of a supercharger. Can that charger hold that much boost?
#24 |
awesome
#25 |
I was a little slack updating this but just before the end of last year I got this sorted out.
Had another pulley made with a 22% increase in diameter, which landed me this result. (dotted line is the last run with the smaller pulley) ![]() Boost is sitting at 0.9bar (13.25psi) While the kw figure isn't too high at 89.6wkw (121whp for you non metric types) the torque figure went up another 20%! It's quite something to drive now. Also worth noting here that it was tuned with reliability and economy in mind on 95 octane, not 98 (which is available here in NZ). Overall I'm pretty happy with how it turned out. Here's a bonus pic of my new intake pipe to fit the 55mm throttle body (4 bolt type from an 1zz)
#26 |
![]() Drives: VITZ RS1500 Join Date: Mar 2006
is it no way to factory bolt on to the 1zz throttle body?
thanks for your sharing,really enjoy it!
#27 | |
hope this helps :) |
#28 |
![]() Drives: Toyota Echo Join Date: Feb 2014
Great write up mate, keep us posted :D
#29 |
![]() Drives: yaris s 1.0 Join Date: May 2012
#30 | |
What's wrong with the s/c you bought? I know that sometimes the teflon coating fails but that can be re-done. |
#31 | |
#33 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Great build up.
Are you still using a standard gearbox? |
#34 |
2ZR swap. DO IT! Ask how!
LOVE the sound! I've finally gotten my S/C build under control and it's been phenomenally fun to drive.
#35 |
Still using the stock gearbox. It seems to be handling the extra torque fine.
I've just been offered a 6 bolt TRD LSD for it, but sadly I'm now selling the car to make room for another project so I'll have to decline. :( If I had the garaging I'd probably keep it cos it's SO MUCH FUN! |
#36 |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Nooooooo, keep the Vitz dream alive :(
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
| Tags |
| 1nzfze, jimze, supercharged, supercharger |
| 2NZ-FE Supercharged Limits | iwanttobeamole | Forced Induction Forum | 8 | 11-21-2016 04:59 PM |
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 10:56 AM |
| Supercharged 2nz-fe VVTI tuning | iwanttobeamole | Forced Induction Forum | 2 | 09-02-2012 07:30 PM |
| ++JIMZE SUPERCHARGER++ | MANSETH | Forced Induction Forum | 17 | 07-07-2010 12:47 AM |
