#1 | |
Mr. 155 and climbing
The important thing to remember is that it really should be a temporary solution. These sending units don't like vibration. When we have more time we will mount remotely on a hose. sent from my m-o-b-i-l-e
We can do that.
Any of the FI guys using a 3-3.5" thick/deep FMIC by chance? I am curious about clearances. Right now my FMIC is 2.5" thick/deep. I am wondering if anyone can confirm whether or not you can actually go as deep as 3.5". If so it opens up a lot more options since going with a taller version won't buy you much with the crashbar being in the way.
Ordered a new FMIC as well. After further review looks like I will be going with an upgraded intercooler too. Current one is a fin type 28x5.5x2.5 1 5/8". A new bar and plate type 28x7x2.5 2.5" is on the way. I didn't really know about IC design when the first setup was purchased. I am pretty curious if I had gone bar and plate before along with bigger injectors if I would have been able to squeeze 15-20 more hp/tq. New IC will be here by Tuesday.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Those badlandz cut outs are a joke. People bring them in all the time to be installed. They leak and ive seen several go bad within a few months.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#6 | |
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. Last edited by fnkngrv; 05-04-2014 at 03:53 PM. |
A few more new install pics.
Spark plugs that I will be using when racing and running over 20psi of boost: sent from my m-o-b-i-l-e
Also today we found something interesting on the original turbo. Not really sure when this began to happen, but the weld began to give way on the internal wastegate flap. Started to peel like opening a Lunchable so I was losing plenty of actual pressure. Who knows.....could have been doing this when I did runs last year. Only speculation, but then it is entirely possible that I could have broken 150mph in the 1.5 mile course even with the current at the time fuel system setup.
The new FMIC arrived today. Now with this it will require new couplers so those are on the way too.
![]() Also we wrapped up the fuel regulator and line install to the rear of the car preparing for the install of the new fuel pump and inline filter. ![]() ![]() Also relocated the water temp sensor for higher accuracy from the lower radiator hose which of course is going to show much cooler since it is on the inlet side of the motor.
The kittens are really appreciating you posting daily..
I have been debating on where to wire my coolant temp sensor also.. I wasn't sure if I should to with lower or upper radiator hose.. I would think lower would have been better because you would get the temp sooner if you begin to overheat. But then the upper would be good because then if the fans stop working then you would see a rise there too sooner.. I don't know, I guess it really doesn't matter right? At some point the coolant temp will increase if it gets too hot
The biggest problem with this car is that the preferred location is so tight where the draincock is on the rear of the block so that is just about out as an option. The problem with using the lower hose is that it is the coldest your coolant will be since it is just as it has left the radiator. At that point you are guessing what the temp really is in the engine. Best guess that seasoned racers have told me is that you need to add 35-40° to what your gauge is showing with it being on the lower hose. We have discussed tapping the block on the drivers side in the future and taking it off the hose altogether, but that will be very tight quarters too.
You could also intersect the hoses that go into and out of the throttle body.
OMG SCOTT,
you're Brilliant.. but what adaptor would be best to use on those hoses? Just "T" one of them off and add a sensor at the end of one of them?
That's how I would do it. I think it would give a bit closer to actual engine temp than the radiator hose would.
Maybe I missed it, but why are you not sourcing the water temp from the factory sensor in the head? That is where I pull mine from.
Then I use the MI sandwich adapter for oil temp and pressure. Easy.
#16 | |
As for the sandwich adapter I will be selling mine. I spoke above how I will be moving the oil pressure sending unit even off the T. I prefer not to run sandwich adapters. Case in point that my jack was run over during the winter and I had to change the oil about 6 weeks back. I had no choice but to take the car to a shop. I told them that the sandwich adapter was there yet they still somehow ended up loosening it and then it caused a leak after the oil change plus the tech damaged my sending unit in the process. Not worth the trouble if I end up in a bind.
0-60 in slow
Not to pick nits or anything, but wouldn't you want to source the temp data from the head and not from a coolant hose? Since there is already a boss for the temp sensor it seems like a no brainer.
In the crapcan enduro car we decided against the hose sensor because it was just another avenue for failure and the temp data wasn't going to be good enough if there was a leak or some other failure. |
#18 | |
http://shop.microimageonline.com/ScanGauge-II-SGII.htm
