Old 03-14-2014, 03:09 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by Kar98 View Post
It's popular with the VW crowd to put for instance a Golf III dash into a MkI, or a Corrado dash into a Scirocco, but that's only possible because of a totally different approach to the design.
For instance, you can get programmable intermittent wipers in a '84 Rabbit MkI simply by plugging the relay module from a '08 New Beetle into the empty spot on the relay and fuse block, thus upgrading your wipers from on/off to off/programmable intermittent/slow/fast. Try that with a Toyota.
So you can just saw the ends of a Golf III dashboard and stuff it into a MkI Scirocco, plug everything in and it can be expected to work. On our Yarii? Fugeddaboudit.
you only need to swap a prius wiper stalk in, and voilą.. variable speed intermittent.
or from a 07+ camry if you have a sedan..
edit: you don't get intermittent rear wipers, but i believe CTScott had made a module that will do it.
Old 03-14-2014, 06:43 PM   #2
Kar98
Drives: 2011 Scion tC
Crap, I had forgotten about that. Meant to do that, but it had somehow slipped my mind. Ordered a Prius stalk. Thanks for reminding me.
Another Prius part that fits elsewhere is the rear wiper, to give the Scirocco II's rear a more modern look ;)
Kar98 is offline   Reply With Quote
Radio swap from 2012 LE/SE into a 'L' richard_rsp In Car Entertainment + Electronics (audio / video / alarm) 28 02-18-2014 11:20 AM
2007 yaris snow tires on 2012 lomky Third Gen Yaris General Discussion 4 11-16-2012 02:00 AM
Buyout 2007 or lease 2012? Walnutcrunch New YARIS Purchase Forum 11 06-03-2012 02:19 PM
