Old 03-15-2014, 10:15 PM   #1
beeks81
Drives: engine only
If the car that I'm getting parts from has ABS what else would I need to make it work.
beeks81 is offline   Reply With Quote
Old 03-15-2014, 10:24 PM   #2
You would need the ABS Pump/ECU as well as the wheel speed sensors.
Old 03-16-2014, 04:56 PM   #3
beeks81
Drives: engine only
Just to be clear. You are saying that the engine would not run with the ABS ECM with out the wheel sensors and ABS-pump wired in. Even if the wheel speed sensors and brake pump are not connected to the wheels.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Cut Power Steering Wiring - Repair or Replace? mdyarisguy DIY / Maintenance / Service 1 07-28-2012 01:10 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
