Old 03-25-2014, 12:58 PM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
realcamber.com makes -3 or -5 degree shims. He makes them for Scion XB/XD and Yaris/Prius. Just like Sugi said they install identically to the hub spacers in that link, that is the link I used to install mine as a guide. They are thinner on the top and thicker on the bottom. The Fab work is perfect and ive ran mine for about a 14 months or more without issue. The seller will include studs to use and provides even longer ones if you plan to run a hub spacer in addition. Remember these are fixed so chose your size wisely as they are very expensive for what you're getting. Also being that this is just a slash cut spacer you will be adding some negative effective offset so dont forget to account for that.
Could the 07-08 yaris s front lips actually fits 2010 yaris? Adward10 Cosmetic Modifications (Exterior/Interior) 3 03-18-2013 12:06 AM
January 2010 Yaris Sales Thirty-Nine General Yaris / Vitz Discussion 8 02-03-2010 12:50 PM
