Old 03-27-2014, 08:48 AM   #1
alan27
Drives: 2007 yaris
Thumbs up found it
OK. The next step up from that fuse is the 120A fusible link on the positive battery terminal. If you remove the red cover you will see the two fuses built into the black plastic chunk.
Did it suddenly stop working or did it start after you did some work on the car?
ok i found the fusible link ENGINE COMPARTMENT 60 amp is good and the 120 side went bad so i guess ill be calling around to find 1 befor i call the dealer
alan27 is offline   Reply With Quote
Old 03-27-2014, 09:38 AM   #2
Dealer or junkyard is likely the only place you will find it.
Old 03-28-2014, 05:35 PM   #3
alan27
Drives: 2007 yaris
OK PART IS IN THE THE ONLY THING I SEE WORNG IS NO POWER TO THE RADIO WHAT SLOT # IF THE FUSE IN
Old 03-28-2014, 07:47 PM   #4
ACC fuse in the under-dash panel and DOME in the under-hood panel.
Old 03-27-2014, 10:23 AM   #5
alan27
Drives: 2007 yaris
14.00 bucks for the part from the dealer ship
Will not shift into park AlaskaYaris DIY / Maintenance / Service 7 02-19-2013 12:37 AM
Car got stuck in gear? mr_miles DIY / Maintenance / Service 1 03-24-2012 11:25 AM
Auto trans : Drive to Park + Handbrake : was not in park... Maxh91 General Yaris / Vitz Discussion 7 06-11-2009 06:37 PM
"click" when shifting into park The little red pill General Yaris / Vitz Discussion 2 05-25-2009 12:43 AM
September 22-23rd Colt State Park, Bristol, RI Meet!!, come one come all!!! dexter_5000 New England 17 09-24-2007 01:43 PM
