![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Hey, thanks alot for the write-up!
Are sedan and hatchback window regulators interchangeable? According to an ebay listing, the seller states that they are but I just wanted to confirm. Do you also have a link to where you purchased your switches/relays? Is it possible to use a stock toyota relay for this or would that unused 60A connection be the best? So you basically used the pink wire in the ignition for the signal but would it be easier to connect it to the cluster for the signal? Sorry for all the noob questions and thanks again! Last edited by 07liftback; 03-28-2014 at 08:11 AM. |
#2 | |
I purchased the switches from a1electric.com You can not use a stock Toyota relay, as it would require changing the body ECU (since the relay lives within there) and the body ECU is within the under dash fuse panel. An aftermarket power window relay is your best option as it directly wires to the window motors. For where to grab ignition switched and high-current power, see my remote start DIY below: http://www.yarisworld.com/forums/showthread.php?t=24860
![]() Drives: Yaris Join Date: Nov 2014
2010 Totota Yaris Sedan without Power locks and windows
Hi Scott,
I recently bought a after market power windows and locks kit for my yaris. I am planing to install it by myself. I can install everything but I don't have knowledge about how I can get the main power and the ground. Could you please give some advice for that? Also when I opened the rear door I saw round unused prong plug after removing rubber bush that was connected to the body. Those plugs are in both side. Can I use this plug or wires to install the power window kits. Is it just installing the fuse so there will be power to these wires? Thank you |
#4 | |
I would need to see a picture of the connector you found. You may be able to use the wires, but the non-power body ECU won't supply power to them, so you would just be using the wires.
Thank you very much. I found the document. Is it the thick black wire or blue wire?
And is there specific way to connect these wires? Do I have to cut the wire? Also I will send you a picture of the connector later that I am talking earlier. |
| Tags |
| power windows |
| Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 10:03 AM |
| Power window | mamun22s | DIY / Maintenance / Service | 1 | 08-30-2012 07:35 AM |
| POWER WINDOW POWER SOURCE IN DOOR PANEL? | mrrock | DIY / Maintenance / Service | 5 | 03-21-2007 06:27 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 09:57 AM |
