Old 04-10-2007, 09:21 AM   #1
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
I saw a formula one time (@ genvibe.com) that calculated power increase/loss based on the air temperature, and according to that, most short ram systems actually caused a HP loss... their positioning usually pulls in air that's closer to the engine (hence warmer) than the stock airboxes. Dunno' how accurate that would be though... the math looked impressive. There was multiplication and decimals and stuff!
Several people on that site were very unhappy with the short rams... claimed a substantial loss of low end.
However, if warmer air leads to better mpg, a short ram may be the ideal thing to increase a Yaris' already impressive ratings, while making throttle response quicker!
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 04-10-2007, 10:22 AM   #2
ChinoCharles
Drives: LB
~YR
I plan on doing some testing in the next few weeks to confirm or deny this, but from what I have come to understand the temperature difference in air between a CAI that takes air from the wheel well and a short ram that takes from the engine bay is negligable. Think about it... a proper CAI has a substantial amount of tubing running through the engine bay, and despite aluminum's heat properties it cannot totally prevent heat diffusion through the pipe and into your air. I would guess the temperature difference in the end between a CAI and short ram intake is negligable, but like I said, I intend on finding out for sure.
Which one you grab depends on what you want from your car. Each has its advantages and disadvantages.
Old 04-11-2007, 12:36 PM   #3
Yaris Revenge
Drives: Lagann. ;P
Think about it... a proper CAI has a substantial amount of tubing running through the engine bay, and despite aluminum's heat properties it cannot totally prevent heat diffusion through the pipe and into your air..
I agree there. I bought some header wrap to put on my Vibe's CAI for that reason. Never got around to it, though... blew the MAF sensor thanks to an unlucky shot with the water hose, and decided to go back stock.
~YR
Old 09-15-2007, 10:18 AM   #4
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
~YR
I know this thread is old, but since it was bumped allready..
After I installed my Weapon R short ram the intake temps decreased by about 10 deg. over the stock air box. the scanguage said so.
AlphaFox is offline   Reply With Quote
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
Intake VS modified filter housing Spades Performance Modifications 19 03-30-2007 12:30 AM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
Reviews of Weapon*R Intake system.. WRLEO Performance Modifications 6 02-20-2007 10:12 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
