Old 03-30-2014, 07:29 PM   #1
coffiend
coffiend's Avatar
Drives: 08 Black LB
The code showed 51. I saw that you posted somewhere where all the codes meant, but I can't find it again, any help would be appreciated :)
Old 03-30-2014, 08:07 PM   #2
51 is a short or open in the driver's side squib circuit, so either the cable from the spiral cable to the airbag got pinched or the spiral cable is damaged.
I would suggest popping off the airbag to take a look (disconnect the battery first).
If you have a multimeter I can walk you through checking where the problem is.
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
