Old 03-31-2014, 12:54 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I hear ya rice. I just think that it would be cool if someone did the 4e-fte swap showing another real option. I had considered the 2zz a long time ago then dismissed it because of the extra couple hundred pounds it it could end up being on thw front suspension. If you do the 2zr just make sure it is from the xD and not the previous years sin e there is the documented oil consumption issues. Yes the 1nz is a very capable engine, but as many have noted a pretty expensive one. Just a harness, switch to MAP, and full standalone is over 2k and I speak from experience.
From my m-o-b-i-l-e
Old 03-31-2014, 01:57 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
From my m-o-b-i-l-e
Aren't you going to run into that issue with any Toyota engine? I don't think any Toyota OBD2 engine has great tuning support outside of the trucks.
I'm stuck dealing with OBD1 tuning issues on a Miata, and I just can't see why you would want that. OBD2/CAN is great from a tuning, and diagnostic standpoint.
Old 04-01-2014, 09:08 PM   #3
fnkngrv
fnkngrv's Avatar
Thomas has an OBDI 4ag and doesn’t seem to be having any problems. The beauty with the 4e-fte is that it gives you options down the line since it has beffier rods stock and a great compression ratio stock as well.
From my m-o-b-i-l-e
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
