#91 |
Good Morning,
I joined this group just yesterday and this is my first post. I first changed my oil on my 07 S Sedan at 2,000 miles and have switched to Mobil 1 5-30 with OEM filters. I now have a filter/oil change every 5,000 miles. I commute daily and my combined mpg is 41 (my Yaris is now one year's old, 15,000 miles). Following is an interesting site I found that not only discusses oil, but other aspects of the car: http://www.chris-longhurst.com/carbi...oil_bible.html |
#92 | |
der Zeck
#93 | |
#94 | |
Drives: 2007 Yaris LB Join Date: Mar 2007
Using synthetic means not having to change the oil as frequently. So not only does it save on gas, it also saves with oil changes that are less frequent then if mineral oil was used. To change the synthetic oil as frequently as mineral defeats the purpose of using synthetic in the first place. Black Yaris, put the pipe down man....
#95 | |
The every 3,000 miles changing rule was dead 25+ years ago...what has kept it alive are a very crooked auto industry and oil industry. The reason Toyota dropped their requirements recently from 7,500 to 5,000 was because of the gelling/sludge issues with their Lexus engines because there were owners that didn't garage their cars at night, causing condensation of water inside the engine, causing the oil to gel or sledge up...and NOT because the oil broke down with more then 5,000 miles of usage....it's a water thing. But for those that garage their cars at night or live in climates that produce no water condesation in the engine over night, this issue is moot. |
#96 |
All makes have the gelling/sledge problem....it was Lexus that has been more publicized as of late, but if you do research you'll find the same issues with nearly ALL car makes. The bottom line is that regardless of the car make, if the car is allowed to collect condensation at night, it will have a sledge/gel problem with the oil....Lexus owners are more likely to have the $$ to make noise in court....one reason why you'll not hear of this issue from Hyundai owners ;-)
#97 | |
OTHERWISE, for owners of other cars, one should NOT use synthetic oil before the engine is broken in, and to do so can effect engine performance down the road. |
#98 | |
Why do you think that the Yaris TSB for lighter oil usage WAS NOT ISSUED FOR CALIFORNIA TOYOTA OWNERS! I was at the dealer today, and he could not find that TSB on his computer...he did find it for other parts of the USA (cooler climates) however. |
#99 | |
der Zeck
#100 |
der Zeck
fine, cold climate only then,... I am still running 0w20, Cali is it's own world with is own rules.. and you Pavel seem you have your own lil sub Cali bubble where things work ass backwards for some reason...
#101 |
so was buying 5W-20 a bad thing? guy from NAPA said it was fine, and that 0W is only needed in extreme cold climates.
#102 |
der Zeck
5w20 is fine, don't mind Pavel, he lives in his own world.... If this easies your mind at all the Prius takes 5w-20 from the factory as well, many chryslers take 0w40 in ANY CLIMATE, that includes So. Cali
#103 |
#104 | |
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
with regards to the oil grade, simply put, the lower the first number, the lower the outside temp can be for starting your car. it just means it can be freezing outside and your oil is still doing its job. the second number is the trickier one. i know that all small hondas (fits, civic, etc) can take in 20 viscosity oil, for better fuel efficiency (lower friction coeffecient in the engine). your oil will do just fine. it wont ruin your engine and you'll probably get better mpg because of the viscosity level. i havent seen any tsb regarding oil 5w or 0w-20 oil yet, but im sure if people here say it exists, then it DOES... --B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
#105 |
yup, getting better gas mileage with the 5W-20 synthetic oil.
#106 |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
I did some research on 5W-20 and 0W-20 and found that it will give better mileage, but may cause more engine wear over time compared with using 5W-30 or 0W-30. This was all discussed in a thread about the Toyota 5W-20 TSB. This is due to the size of the suspended particles staying the same but the film thickness is decreased. I'm sticking with 0W-30 and Napa Gold filters. Maybe even a mixture of the two weights. hmmm....
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#107 | |
--B
#108 |
hmmm, now you have me worried, but then again, Black Yaris said that the Prius comes with that weight and viscosity oil.
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 09:43 PM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 09:15 PM |
| Oil Question | 91drggndime | DIY / Maintenance / Service | 7 | 03-23-2007 07:52 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 09:44 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
