Old 04-02-2014, 07:34 PM   #1
You need to remove the silver panel, which you do by first removing the two vertical black pieces (just pull them off with your fingers, starting at the bottom). Once the black pieces are off pull the speedometer trim back while also pulling the radio trim back. Once those are loose you can pull the A/C control panel off. The knobs snap into slots on the back of the silver panel. Those slots are likely damaged, so you can either replace the panel (or the knobs depending on which side broke) or glue them where the tabs should have latched. Epoxy or Automotive Goop works well.
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
2009 heater/ac control knobs Sodium Duck Cosmetic Modifications (Exterior/Interior) 49 01-12-2009 05:49 PM
Bulbs For Behind The 3 Climate Control Knobs razzorjet2 DIY / Maintenance / Service 2 04-06-2007 10:41 AM
