Old 04-04-2014, 08:54 PM   #1
Rigaud
Drives: 2009 Yaris
It's normal for an automatic if you don't warm it up and no block heaters don't warm up the tranny.
Old 04-05-2014, 07:49 AM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by SchrodingersCatSK View Post
For most people, yes. Problem is, we drive so infrequently that a block heater timer would be useless. I walk to school in the winter, hubby has a truck provided by his job for getting around, so we only use the car for errands. So to run the block heater 24/7 just for the 2-5 times per week that we make a quick trip to the store or an appointment, it would be a huge waste.
Hubby also has a theory that block heaters are unnecessary. The car gets "used to" them and then it won't start without them. We didn't use a block heater all winter on our '97 Tercel, and it only failed to start the one day it was about -50C overnight. Most of the cars that were plugged in didn't start either. *But* I can see your point that by not using one, you're either going to have to pre-heat the car longer or else suffer the poor mileage from a cold car, and either way will consume gas. So that could certainly be another factor here.
Is there somewhere I can get a "checklist" of simple maintenance procedures to improve mileage? We bought the car used, it was previously a rental (only found that out after, when I found Enterprise invoices in the pocket behind the passenger seat), so I'm sure it's never had anything but the bare essentials done in the last 2 years.
Yea, a timer is silly, but you can just plug it in 20 minutes before you need to take it.
As for simple maintenance stuff if you have an owners manual it should be in there, if not This website is also great.
Plus the maintenance section of this forum is a good tool as well.
That is correct. Transmission heaters warm up transmissions.
Colin Chapman disciple
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Why sub-compacts and compacts get almost the same MPG Kal-El Off-topic / Other Cars / Everything else Discussions 0 08-10-2011 11:51 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
