Old 04-10-2014, 01:30 PM   #8
Jason@SportsCar
Those steering ratios can't be right. The 2015 Honda Fit steering ratio is 14.1. The Nissan Versa is 16.8. A Ford F-150 has a 20.0:1 ratio.
EDIT: It does say those ratios even on Toyota's press material, but it cannot be right. My Suzuki Sidekick has a steering ratio of 19.4:1 and I assure you its steering is MUCH slower. Plus, the previous-gen Yaris has a 19.7:1 ratio.
The numbers CT posted are the degrees of steering angle at the wheel each trim level has, not the actual ratio. Toyota math.
Working it out based on number of turns and degrees of available wheel angle it should be 18.19 for the SE and 21.6 for the rest.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering column compatibility between Euro Yaris and US Yaris Micropurchase Third Gen Yaris General Discussion 19 09-17-2012 12:00 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 05:39 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
