Old 04-15-2014, 02:45 PM   #1
frambach
Drives: 2008 Liftback
What would be the 'normal' tire size you'd use on this for a lowered Yaris?
Any center caps?
frambach is offline   Reply With Quote
Old 04-16-2014, 09:58 AM   #2
3cyltrbo
Any center caps?
Don't have SSR caps, but do have some that were made on a 3D printer.
"normal" tire size would probably be either the stockers or something as big as 205 wide.
Personally I prefer I'd use a 195/50/15 or a 195/55/15 or even a 185/60/15.
All of those would give good performance, wouldn't rub and would maintain some sidewall height for ride comfort etc....
You could also do a 205/50/15 pretty comfortably depending on your suspension setup etc....
If you just mounted the stockers on these you would notice a significant change in pep (from the weight savings)
3cyltrbo is offline   Reply With Quote
