Old 04-18-2014, 05:20 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
alternator out put reading from the OBDII/Scangauge was 13.7, and the battery isn't very old It is only about a year old, but I guess I will test it, and make sure the connections are good.
It hadn't done anything like this since i had a short in the column from the fog light kit.
I did take the Battery out Wednesday to get to that tranny mount and tighten it up, makes me think that It might be making a poor connection at the battery some how.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 04-18-2014, 07:13 PM   #2
13.6 is OK, so it very well may be the battery connection.
07 Yaris loses electrical power intermittently. elcam84 DIY / Maintenance / Service 7 04-26-2014 08:15 PM
electrical problem 2007 5 door hatchback fford Canada 3 03-21-2013 02:02 PM
What electrical polisher do you use? tomato Wash, Wax, Detailing, Exterior Repairs 11 09-01-2009 12:34 PM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
