Old 04-26-2014, 02:16 PM   #1
detroiter
detroiter's Avatar
Drilled stock airbox
I was cleaning out the garage and found a second stock airbox configuration that I forgot I had. I was thinking about the airbox mod that's been here on the forum for a long time and figured, why not? So ended up drilling nickle sized holes in 3-5 lines all the way around the lower box. Needless to say, I wish I would have done this a long time ago, reminds me of the growl and sound the AFE intake gave me but obviously as a much lower price. That's not to say the AFE or any other intake is a bad thing, they look much nicer than a stock airbox. But if you're on a budget, it's a mod that's worth looking into
I'd like to give ChinoCharles credit for this one. It's his thread that gave me the idea to go ahead and make it happen.
Old 04-27-2014, 10:14 PM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
You should remove the carbon trap so you might make use of the additional available flow
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-28-2014, 10:55 AM   #3
detroiter
detroiter's Avatar
Thanks for the tip! Any effect on the MAF sensor though? So far I don't really see any change in MPGs or anything like that, just much louder (and nicer sounding!) under acceleration.
Old 04-28-2014, 11:18 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Removing that wont effect the MAF sensor.
-Derrick-
Old 04-28-2014, 11:30 AM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I did this exact same thing when I first had my Yaris in 2007. Adds a nice sound.
Old 04-28-2014, 12:23 PM   #6
7:34pm
Drives: 07 Yaris
I'm bored and have the day off... so what size drill bit are we using, and we're drilling below the panel correct?
7:34pm is offline   Reply With Quote
Old 04-30-2014, 12:27 PM   #7
Thirty-Nine
Here's what I did.
http://www.subcompactculture.com/200...-my-yaris.html
Old 04-30-2014, 05:01 PM   #8
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
How does it sound?
monchito18 is offline   Reply With Quote
Old 05-01-2014, 12:33 PM   #9
Thirty-Nine
Originally Posted by monchito18 View Post
How does it sound?
It sounded great at WOT. I have the K&N Typhoon now.
As far as heat soak, any short-ram-style intake is going to likely suck in warm air. They're probably more of a noise maker than anything.
Most stock intakes are designed so well these days that it's unlikely any gains of more than 1-2 hp could be made if that unless you're already making serious power (e.g. Garm's old Yaris).
Old 05-01-2014, 05:44 PM   #10
Rigaud
Drives: 2009 Yaris
On a 1.5L engine you don't get more then maybe .5 h.p., better throttle response and noise. Whether a short-ram or a long cold air intake theirs no power gain really. Been a lot of studies and research on that and like you mention, their so well designed now. On bigger engines 5.0L and bigger theirs an increase.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 04-30-2014, 01:09 PM   #11
detroiter
detroiter's Avatar
Wow and I thought mine looked awesome lol. Good job!
Old 04-30-2014, 09:46 PM   #12
detroiter
detroiter's Avatar
Here's basically what I did...goes all the way around the lower portion of the intake box
Old 04-30-2014, 09:53 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
[QUOTE=detroiter;735854]Here's basically what I did...goes all the way around the lower portion of the intake box
that should make for some cool sound ...if u can post sound with intake running that would be fantastic .
One question ...what style air cone makes most sound open or closed end ?
Old 05-01-2014, 12:04 AM   #14
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
DOING THIS THIS WEEKEND!
trunkout is offline   Reply With Quote
Old 08-11-2014, 11:02 AM   #15
driverofchuckles
driverofchuckles's Avatar
Drives: 2008 Yaris. Manual everything
Getting ready to drill this exact moment!
driverofchuckles is offline   Reply With Quote
Old 04-30-2014, 11:21 PM   #16
detroiter
detroiter's Avatar
At lower rpms with hard acceleration, it kind of reminds me of a boxer engine from a Subaru WRX. At higher rpm hard acceleration, reminds me of some Honda VTEC hah.
I'm using a high flow air filter as well.
Old 05-01-2014, 02:19 AM   #17
yariseggvvti
Drives: Yaris Hatchieback
I didnt drill any holes in the box. What I had done is took out the tube from the lower air cleaner box and put a K&N drop in filter. Sounds deep and once the VVTi active is screming.
yariseggvvti is offline   Reply With Quote
Old 05-01-2014, 05:30 AM   #18
detroiter
detroiter's Avatar
I've had the "elephant trunk" tube off for a long time...it does add a deeper sound. Once the holes are added, it's MUCH deeper than that.
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
HELP need STOCK wiring harness for stock deck ya_RS Canada 0 09-26-2010 05:50 PM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
STOCK SEATS OUT OF HB / stock tires/rims mrrock Items for Sale by private party 19 08-19-2009 04:56 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 04:19 PM
