![]() Drives: Yaris and dc2 Join Date: Apr 2014
Engine light
99 toyota yaris 1.0 Change air flow meteor didn't work lambda sensor made car run rougher What is happen is car IDE low engine light on sluggish in morning has to have nearly full tank petrol . When I changed lambda sensor the car would not rev over 2000 when heat up it wouldn't rev over 4000 then cut out when going take off . There's sucking sound in engine bay when ide to low any help
Did you read the code to see why the light was on?
Lean fuel and miss fire
OK. With that and your hiss, it sounds like you have a vacuum leak. Check all of the vacuum hoses and the PCV hose for a leak.
I check all hose no leaks when I squeeze the pipe to black canister it stop the sound the suction pipe when I take of opposite pipe I cannt feel the suction through the canister is that ok . is there any way I check fan in car can I turn on it by
put power to it see if works |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| 2012 Yaris LE Check Engine Light On/Eco Light Off | 2012YarisLE | DIY / Maintenance / Service | 1 | 01-22-2014 11:29 AM |
| Engine light came on but seems to run fine | naossoan | DIY / Maintenance / Service | 7 | 06-10-2013 04:51 PM |
| check engine light, engine turns but not start | willygoodness | DIY / Maintenance / Service | 10 | 07-23-2012 05:10 PM |
