#217 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Folks get way too hung-up on MPG,they drive themselves "crazy".From the first page: Turning off your engine at all of those intervals is ridiculous,keep your engine in a good state of tune and be done with it.
#218 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
How are people getting 38mpg?
are you guys looking at instant mpg, looking at your scan gauge, or are you calculating your per tank mpg? Somehow skewing the numbers? 38 psi in the tires a/c on most of the time I drive on average 25 miles one way to work 70-80mph I only see 32-33 mpg per tank Average 326 miles on 10 gallons I fill the tank completely every time This is summary of every fill up (partial and full) since owning my '14 Sent from my metallic purple honami
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#219 |
#220 |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Best economy is 50mph and below.
#221 | |
#222 | |
Page 3 -- member lgcharlot: 37 MPG at 70 MPH for a couple of California to British Columbia road trips (member = a 4 post wonder) Page 4 -- member Maypo mentions peak fuel economy was 39 MPG at 75 MPH -- closer attention reveals he is talking about a Fiat X1/9 (who knows why he is mentioning an X 1/9 (member = a 1 post wonder))page 12 -- member Bilstein mentions 39 MPG at 75-80 MPH...but his tire pressure is at 50 PSI. page 13 -- member Amdkt7 mentions 38 MPG at 70 MPH with a full load of people. The nature of all of his posts....overall, the hills probably help a bit, but I think he just has a stellar focus re his driving habits. page 14 -- JimKellyfan -- 38 MPG at 80-85 MPH....aided (I imagine) by the downhill part of the trek (he uses 'uphill' in reference to the return) side note: Page 2 -- Keesue's reply to Nigal -- set tires to 32 PSI and MPG improved....same thing happened to me when I did same (down from 38 PSI for me) sometime after last summer. In the past, PSI increase = MPG increase in my experience. |
#223 |
I don't see how I could get another 4-5 mpg... Im not going to be able to decrease speed (Florida drivers are bad) and I'm pretty sure temp and humidity are factors, and even if I turn ac off, it will be negligible at highway speeds....
#224 |
My best I posted in "Fuelly" is 38mpg and my worse 30mpg. Cold damp weather this spring and on winter tires. I only posted twice for two fill ups. Got my summer wheels on and doing short 5 miles return trips around town plus some 35 miles trips on the highway but nothing under 65mph on highway. My very best this winter was 40mpg on a road trip, temps 20f hardly any wind. Next road trip I'll see how much better I'll do especially once I install a cruise control on it.
#225 |
![]() Drives: '08 Yaris Join Date: Apr 2014
In my area with my driving conditions I'm seeing good numbers, but still early in my miles tracked and learning my vehicle. I will be picking up lighter wheels and tires and lowering a bit which I hope will get me close to 50mpg average. I never run a/c, typically just driver window down getting a left arm suntan.
I am only using DFCO and keeping speeds around 60 when possible, otherwise if I'm going faster I try to stay 5-6 car lengths behind the car ahead to reduce some of the drag. Considering rigging up an active grille block shutter system when I have time to study how the new cars are doing it, maybe harvest the parts off a wrecked car or something so I can do it on the cheap. Will be picking up a scangauge soon for some live data. |
#226 |
Only Happy When it Rains
Honestly, you aren't driving far enough to get really great gas mileage. And I lived in Poinciana for a few years, florida drivers are not that bad. They can go around you just as well as any other driver.
But the a/c hurts gas mileage, your speed will kill gas mileage, some run much more tire pressure. I average a little above 39 mpg, as calculated on fuelly. ![]() Some tips? Use the gas pedal like it is a nuclear bomb that will destroy the world. Look ahead and plan to cruise to a stop so you never have to hit the brakes. If you have to use a/c, and down in Orlando I can't blame you, turn it off and on so it won't suck up as much gas. If you are on interior air re circulation you can go a few minutes with the a/c off. Also buy and apply the darkest tint you possibly can, legally. I go as slow as I possibly can. I usually do not exceed 50. On highways I go at maximum 5 miles below the speed limit. I try to stay near 50 if at all possible. I generally do not drive long trips, but commuting 50+ miles 1 way makes getting great gas mileage really easy, my best tank of gas was 47 mpg when I had to drive over an hour each way every day for two weeks. Quote:
Colin Chapman disciple |
#227 | |
I agree with all of your suggestions (in other parts of your post) re improving MPG. |
#228 | |
If you want to get up near 40 mpg, you'll need to learn and use many hypermiling techniques and start using a gauge that shows your instant mpg. Some of the techniques can be a burden if you don't want to deal with other drivers getting mad at you, but there are many you can use that won't affect anybody else on the road more than what's normal. Read these two articles, and they should help you quite a bit: 100+ Hypermiling Tips Beating the EPA - The Why’s and How to Hypermile |
#229 |
So you all are getting 400+ miles per tank? Crazy......
#230 |
360-395 miles per tank this winter on snow tires and cold. I'm about to find out what I do on summer wheels. I just drive, not going nuts trying to suck every possible mile out of a tank. If I compare with my Suburban or Audi A6, it's awesome. ;P
#231 |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
as bad as this winter was, with much colder than average temps and 122 inches of snow, my average for december 1 through april 1 was 40.9 mpg's. now that summer gas is here (along with warmer weather), I expect to be closer to 44 mpg's.
5 speed manual. mostly suburban/light suburban/rural driving with speeds usually ranging from 40-60 mph, with about 10-15% true city driving. I do not hyper mile. I do drive reasonably and avoid blasting away from every stop. |
#232 |
I never run past 2 bars and I'm getting almost 400 miles before fillup, if I ran to empty that would be almost 500 miles out of the tank based on my average.
#233 |
4 years of P90X!
I've gotten 45 miles to the gallon. Hypermiling and driving 55. What's the big deal? It's even a sedan. It's technique, plain and simple.
Imagine there is an egg on your excellerator and you have no brakes. |
#234 | |
527.9 miles ----- 11.784 gallons ----- 44.747114 MPG 517.2 miles ----- 12.164 gallons ----- 42.518908 MPG 504.9 miles ----- 11.994 gallons ----- 42.096048 MPG 517.7 miles ----- 12.347 gallons ----- 41.929213 MPG 490.3 miles ----- 11.550 gallons ----- 42.450216 MPG 483.3 miles ----- 11.506 gallons ----- 42.004171 MPG |
| Fuel Level Gauge Stuck ? - 2007 Yaris Sedan | kaboom | New YARIS Purchase Forum | 9 | 05-15-2007 02:58 AM |
| Fuel consumption US Yaris vs. Canadian Yaris | Driver | Performance Modifications | 8 | 10-29-2006 02:27 AM |
