Old 04-30-2014, 09:47 AM   #1
regal
Drives: 09 Yaris 3 Dr White LB
OK this is silly. I have the VIN number from the JY door. But that's not good enough you have to be a paying dues locksmith to get a key code from the VIN, stupid.
Any other way?
regal is offline   Reply With Quote
Old 04-30-2014, 10:17 AM   #2
Any other way?
If you remove the lock assembly and bring it to the locksmith with your original key, they may be able to re-pin the lock to match your existing key.
Old 04-30-2014, 06:56 PM   #3
regal
Probably take me 2 hrs to remove the lock another 2 hrs at the lock smith, can go into work and make $500 for 6 hrs so not worth it.
I found a company that can give you the key code from the VIN + techstream ECU dump for $12 that sounds like fun I may try that route.
