04-30-2014, 04:57 PM | #1 |
Drives: Vitz 2009 Join Date: Apr 2014
DIY, can i install HID which have High and low beam together in Vitz 2009?
Hello,
I purchased this HID and I have been told that I can install in Vitz 2009, but i noticed that in my original headlight high beam and low beam is separate bulbs, and the one i purchased is in one bulb. I want to know is it possible that I can install this in Vitz 2009. Photos are attached. any kind of help will be appreciated. Thank you in advance. |
04-30-2014, 06:32 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Do you have a picture of the headlight on your 09 Vitz? The OEM HID headlights on the Vitz RS have an HID low beam bulb and a separate halogen high beam bulb, but the non-RS Vitz just have one bulb with a high and low filament.
05-01-2014, 02:15 AM | #3 |
if your low and hi beam are seperate...then that hid kit you have wont even plug in to anywhere..you need to get D4R bulbs.
05-01-2014, 11:42 AM | #4 |
05-01-2014, 04:22 PM | #5 | |
Here are the photos of my headlight, if i change the bulb the same kit will work or i have to change the kit also?IMG_0559.JPG IMG_0560.JPG |
05-01-2014, 04:49 PM | #6 | |
Since you already have HIDs, why do you want to change to the kit?
05-01-2014, 05:14 PM | #7 | |
I do not have any knowledge about this stuff, I even didnt knew it that I already have HID :D I have been told that if i get this HID kit, i will have much brighter light and i purchased it. do you think that with this 55w HID ballast kit i will have more light? if yes, i can do the wire changes if you guide me. Thank you in advance for your help. |
05-01-2014, 06:26 PM | #8 | |
If you still want to do the conversion, I recommend getting a set of non-HID headlights and using those with the kit. You could then sell those OEM HID headlights for a significant price.
05-01-2014, 10:55 PM | #9 |
sell it to scott :P wait...is turkey driving on the same side as US? i think it does...
05-01-2014, 11:02 PM | #10 |
He's got a Vitz, so they must be RHD headlights?
05-01-2014, 11:04 PM | #11 |
but it could be those french built ones, and there are a few LHD countries!
05-01-2014, 11:11 PM | #12 |
But then it would be a Yaris, rather than a Vitz.
05-02-2014, 08:26 AM | #13 |
Most of Europe are LHD.
05-02-2014, 08:32 AM | #14 |
Yes. But, if he actually has a Vitz it will have been imported from Japan, rather then being a European Yaris. That is pretty common in some areas over there (like Malta for instance).
05-02-2014, 05:47 PM | #15 | |
Drives: Sedan 07 Join Date: Oct 2012
Even in the philippines where they are/need to be converted to LHD but still referred to as their original (JDM) names (vitz (yaris), fit (jazz), etc.) since the local (PhDM) versions are called their local names. |
Tags |
diy, hid, high beam, low beam, vitz 2009 |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY Low intensity high beam ? | JudgeM | DIY / Maintenance / Service | 1 | 12-08-2013 08:01 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
Does anyone know how to rewire a Low beam HID kit, for both LOW/HIGH beam use? | Syroyizhka | General Yaris / Vitz Discussion | 1 | 11-30-2009 10:47 PM |
Package received from Taiwan! | GabL | Cosmetic Modifications (Exterior/Interior) | 74 | 09-25-2007 09:37 AM |
