#1 | ||
![]() Drives: Yaris P1, MR2 mk1, 4x4 Hiace Join Date: Apr 2014
I think the above link is not complete?
I read about the NST and poor customer service etc. You are right from the weight point of view, but I also want it to use less power. So lightweight + underdrive is better it seems to me. |
#2 | |
It is not really a matter of consuming less power. The light weight achieves that. Going 10% underdrive was a way of making the pulley lighter still, while still providing enough rotation to drive a/c, alt, and water pump.
#3 | |
Ok thanks. Could be because of simply different width of the pulley and length of the bolts,.
So why wouldn't underdriving work? Of course I could also put a bigger pulley on the waterpump (might be easier to find) to have the same effect. Of course, the lightweight idea is straightforward and clear. |
It could be that or it could be that they are different diameter bolts. Unfortunately I don't have enough detail on them to be able to tell. You could go you your local parts department and have them pull the three different MK1 Yaris crank pulley bolts to see the difference. Over here we just get the 1NZ, so we don't have access to the others.
#5 | |
The bolts have different part numbers as well.
| Concerns about pulley's | Black_griffin6 | Performance Modifications | 35 | 02-04-2012 12:05 PM |
| Pulleys, pulleys, pulleys! | Deltasix | Performance Modifications | 15 | 03-21-2009 11:10 PM |
| Greddy TI-C, NST Pulleys, etc. | drkmcc | Items for Sale by private party | 12 | 02-12-2009 06:05 PM |
| Drift Yaris + NST Pulleys = :) | thefoth | Performance Modifications | 20 | 11-20-2008 09:03 PM |
| NST Pulleys | hatchbackkid82 | Performance Modifications | 15 | 09-29-2007 08:04 PM |
