Old 05-02-2014, 08:17 PM   #1
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
Just out of curiosity, what is cheap 'total' conventional oil?
What is the brand and weight?
If you are changing the oil pretty much every 5,000 miles and it looks like that under the cap, could be a combination of cheaper oil & more severe driving.
I don't trust engine additives or flushes, either. You need to start using a better quality conventional or synthetic blend oil. Try a few shorter (2000-3000) mile oil change intervals with either Pennzoil Yellow Bottle or Pennzoil Synthetic Blend (I believe they call it Pennzoil Gold) If these are available on your island of P.R. - Change the filter each time! If you are a 'spirited' driver I suggest you shorten your OCI a little bit (in the future) Use a BETTER quality oil & it will clean that varnishing up before you hit 100,000 miles.
Shorten your oil change interval, change the filter each time & use a better quality oil.
yougojay is offline   Reply With Quote
Old 05-02-2014, 08:32 PM   #2
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
Yea it's cheap. Im using the 10w-30
That was one answer I was looking for. I was thinking on changing to a good full synthetic like mobil 1 and make shorter OCI and see if it actually cleans it in time.
monchito18 is offline   Reply With Quote
Old 05-02-2014, 08:59 PM   #3
yougojay
25, 550 MILES!
I thought that was the oil (Total-Total Quartz) Not familiar with it personally but I've seen mention of it on the oil forums.
Mobil 1 is a quality oil, it has a ton of followers. Heck, I just changed the oil on our Benz, used Mobil 1 0W-40
Yes, use a high quality oil, and change it out at shorter intervals.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
