Old 05-02-2014, 08:23 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by yougojay View Post
Thanks! You are correct - It's a bit further under, but it's there. It is a little black button that says 'set' with the tire symbol next to the button. Ya learn something new everyday here, much appreciated for further reference!
unless ur car is older then 2010 dont push black button that is the main set when car is PDI ...if u reset it at 35 psi it will change the threshold now to 35 so now anything under light goes off ...older toyotas had this but at same time they did not have sensors in wheels but hub ...not very good .
HAve To Use Spare: How to disable TPMS light? bronsin DIY / Maintenance / Service 6 01-09-2014 06:20 AM
TPMS questions NEexpat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-02-2013 05:18 PM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
Checking Spare tire Air xairmech DIY / Maintenance / Service 24 04-29-2010 05:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
