Old 05-03-2014, 03:56 PM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
When you do the OPSU, could you take pictures of where you are putting it and the hardware you are using.. I have been debating on weather or not I should get the Sandwich adapter or not, but wasn't sure where I could get another source of oil pressure.
Also, where are you getting a signal for your Water temp gauge? Are you using the signal from the OEM sensor to ECU? If so, what gauge are you using? If not, where did you install your Temp Sensor?
Sorry, I am in the process of doing my gauges and trying to find the cleanest and easiest way to do it.. searching for all my options.
thanks
-Derrick-
Old 05-03-2014, 08:56 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
thanks
Unless there is a space issue we will be installing a T fitting here:
Old 05-03-2014, 09:11 PM   #3
ilikerice
ilikerice's Avatar
thanks, that helps me a lot. Will probably go that route, fairly easy to get to with intake mani off
-Derrick-
Old 05-06-2014, 06:14 PM   #4
fnkngrv
fnkngrv's Avatar
Here you go on the install pics. We reused the oil dummy light location.
The important thing to remember is that it really should be a temporary solution. These sending units don't like vibration. When we have more time we will mount remotely on a hose.
sent from my m-o-b-i-l-e
