Old 05-04-2014, 11:18 AM   #39
Originally Posted by nortonfb View Post
I found a used one from a 2012 sedan. It's cheap enough.
But will it swap out? I can't see any reason just to swap modules.
Unless I can do it in place without removing the alternator.
Is there a DIY on this some where?
You guys are great.
Steve
It will just swap in. For doing the swap you just need a 12mm wrench for the top bolt and a 14mm for the bottom. The bottom one can be tough to get out, so if it doesn't feel like it is going to loosen easily, hit it with some penetrating oil before trying too hard. The threads are on the right side (as you are facing the engine from the bumper) so you want to hit that end specifically.
For replacing the regulator itself, here is what is involved:
http://www.yarisworld.com/forums/sho...05&postcount=2
DIM battery light 2o6 DIY / Maintenance / Service 9 11-22-2012 06:58 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
