Old 05-07-2014, 08:25 AM   #1
mpcv2000
mpcv2000's Avatar
Drives: 2004 Echo HB Hatchback 2 Door
Originally Posted by IllusionX View Post
Seriously.. everything works out of the box? It took 3 attempts in 8 years before someone made it to work properly?
Did you also check your speed vs GPS?
It worked on 1st attempt.
The only thing I haven't done yet is the Hi-Low Beam wiring , I may do it later on when I'm bored and yes everything works like if it came like that from the factory.
I haven't check with a GPS but I don't see why speed should be different
mpcv2000 is offline   Reply With Quote
Old 05-07-2014, 09:56 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Because other member at clubecho-yarisquebec said he had a 20kmh difference in the speedo.
Old 05-07-2014, 10:23 AM   #3
mpcv2000
mpcv2000's Avatar
I'll try to check it this week but according to traffic flow it appears to be right on but I'll check for sure.
Old 05-07-2014, 01:38 PM   #4
My bet is that they messed up the ground connection for the speed sensor to cluster connection. Based on the specs for the signal output in the service manual, there should not be a difference between the two.
Old 05-07-2014, 04:18 PM   #5
mpcv2000
mpcv2000's Avatar
Maybe they mean .02 KMH
I don't have stock tire size so it may read off a little because of that.
Here's what I have : Nitto NeoGen 205/50R15
It's right on.
Now I want some disk brake on the rear .
What is my best option ?
Budget is between $600.00 to $1000.00 .
I have Goggled it a little on it but nothing "easy to grab" came up really.
Old 11-24-2014, 12:19 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Matrix XRS or Corolla XRS rear disc should bolt right on. You'll only need to re drill the rotors for 4 bolt pattern.
I don't know about the park brake cables though.
PS, sorry, I just found this thread now.
Old 11-24-2014, 04:39 AM   #7
mpcv2000
mpcv2000's Avatar
That's good.
I'll look into that this winter.
Yaris Liftback cluster w/tach for SALE!! jose3sgte Items for Sale by private party 5 11-13-2013 10:35 AM
Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS Jabro Willing to Buy by private party 4 12-21-2012 06:34 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
2007 Yaris Sedan cluster, with Tachometer. (Won't fit Liftback) H3LlIoN Items for Sale by private party 3 09-18-2011 03:55 AM
