Old 05-08-2014, 12:32 PM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by Jason@SportsCar View Post
Maybe I missed it, but why are you not sourcing the water temp from the factory sensor in the head? That is where I pull mine from. Then I use the MI sandwich adapter for oil temp and pressure. Easy.
Because the ECU needs the most accurate reading not some additional gauge that has nothing to do with the way engine runs. If I weren't going to be doing what I am doing then I wouldn't worry about it, but I push the engine very hard and fast so this is how I want it to be.
As for the sandwich adapter I will be selling mine. I spoke above how I will be moving the oil pressure sending unit even off the T. I prefer not to run sandwich adapters. Case in point that my jack was run over during the winter and I had to change the oil about 6 weeks back. I had no choice but to take the car to a shop. I told them that the sandwich adapter was there yet they still somehow ended up loosening it and then it caused a leak after the oil change plus the tech damaged my sending unit in the process. Not worth the trouble if I end up in a bind.
