Your car is looking good. Those bulge-type lugnuts should be OK. At least the larger conical section makes full contact with the taper of the rim hole, whereas with the stock ones there is very little contact area.
![]() ![]() Drives: 08 hatchback Join Date: Jun 2011
![]() Drives: Black 2012 SE manual Join Date: Feb 2013
quote> those bulge-type lugnuts should be OK. At least the larger conical
section makes full contact with the taper of the rim hole, whereas with the stock ones there is very little contact area <quote Thanks for the advice CT.. I couldn't locate any extended tip nuts which would fit my wheels. The 0.625" extended tip diameter would not clear my 0.595" rim thru-hole. So I similarly purchased bulge-type nuts which do cover the 0.800" outer conical area. |
| Question about these rims. | Bar_Red_Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-09-2011 08:54 PM |
| My 17" alloy rims and Kumho tires... will swap for your original wheels! | AutoWashCars | NY / NJ/ CT / PA | 5 | 02-08-2011 07:38 PM |
| RIMS a Noob-toob question =] | donchae | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 45 | 10-17-2010 06:11 PM |
| Question about Rims | MrJester | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-06-2007 10:16 PM |
| hufeisen rims | JustYYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 01-17-2007 03:16 PM |
