Old 05-12-2014, 10:01 AM   #1
NEexpat
Drives: 2009, auto, 4dr LB
^ "I hate the TPMS - that alone adds $40 to the cost of whatever I get."
Are you going to replace the TPMS valves?
I looked into the lifespan of these things and depending on cycles and weather people say they last 7-10 years. I just had the tire guys put my new tires on the original wheels with the original TPMS valves.
I brought this up on here and got some advice on whether or not to replace them.
NEexpat is offline   Reply With Quote
Old 05-12-2014, 01:34 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
There is a TPMS valve rebuild kit, that should be done to prevent leaks after a few years.
Old 05-12-2014, 02:57 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
also keep in mind that the life spend of a TPMS is about 4 to 5 yrs give or take...always a good idea to get valve kit also clean rims of from any corrosion a good shop would do that and use rim sealer all this will help with air staying in ur tire . Nitrogen helps too , keeps the tires from psi fluctuation and over all longer lasting tires...yes it does work .
Old 05-12-2014, 07:08 PM   #4
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
TY for letting me know about the nitrogen keeping the tires from fluctuating. I didn't know that and that's the reason I hate the first cold day of Fall and if my tires are right on the borderline, that stupid TPMS light comes on.
DebbyM46227 is offline   Reply With Quote
