| View Poll Results: Will they fit??? | |||
| Yeah, probably |
4 | 40.00% |
| Hell No |
6 | 60.00% |
| Voters: 10. You may not vote on this poll | |||
Ok so maybe I can go for this angle
Firestone spring helpers for front and rear $200 195/75/14 BFG AT $520 from tirerack.com Kosei K1 TS Grey 14" 9.3lbs $476 from tirerack.com Wheel spacers Edit: remove unnecessary body panels hit the trail
#2 | |
The firestone helpers are only for the rear. The fronts have struts inside of the springs, so there is no space for them. The BFGs look like a good choice at 25.5" high x 7.7" wide
How about universal coil spring spacers for the front?
Spring spacers might work, but with them on the front struts the springs would not have any compression range, so the front would be rigid. That VW looks like it is running rally suspension. MCA Suspension makes a setup that would work on the Yaris, but I wouldn't even want to know what it costs.
#5 | |
| All terrain tires for cars? | Captain Slow | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 11-01-2013 11:05 PM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| 2007 Yaris bad tires | weaver615 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-27-2010 07:21 AM |
