Old 05-14-2014, 01:07 PM   #1
Yes. I have Fumoto quick valves on all of my vehicles. The oldest one I have had on for over 5 years without issue. If you are lowered, you need to be careful as the valve hangs lower than the drain bolt head would have.
Old 05-14-2014, 03:02 PM   #2
Silverkarn
Drives: 2008 Toyota Yaris 2D
Car is stock height. They have one that is made for cars that have been lowered. I'll probably end up getting that one as i do go over speed bumps quite often.
Silverkarn is offline   Reply With Quote
Old 05-14-2014, 04:00 PM   #3
marauder
marauder's Avatar
Drives: '08 Yaris
Yep, tried this on my RX-8 and had the same problem. The adapter needed to fit the valve on my vehicle caused the final location of the drain valve tab to be the lowest point of the car and facing the rear of the vehicle. Any minor hit would open the valve. I was told to add washers to adjust the final position, the problem was I needed to clear almost 90 degrees of rotation.
They do recommend you install the safety spring just in case, which I would highly recommend because it also keeps some punk from draining your oil easily should they be crawling around underneath your car for whatever reason.
The valve adapter and safety spring I bought for my RX-8 is still new in the box. I'd give mine to you but it looks like the drain plug size is not the same.
marauder is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
oil drain plug- gasket eddy DIY / Maintenance / Service 38 10-17-2009 11:00 AM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
